× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M1
Samsung1958
Follower
Nighthawk M1
Have no Data usage have spoken to Telstra they are blaming device is there a solution to the problem
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
Re: Nighthawk M1
Your message may be crystal clear to you, but it provides little information for anyone who might be able to help. Take this bit:
@Samsung1958 wrote:
Have no Data usage ...
What does it mean?
No Internet connection? Something else?
What have you done to try to fix it?
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Look for help with troubleshooting.
You have posted your message in the section of this community given over to Apps and Services. (This is easily done, given Netgear's impenetrable community structure.)
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 802 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
