- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M2 offloading issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
M2 offloads to a Samsung Note8 phone hotspot perfectly. Refuses to connect to a Apple iPhone 8 hotspot. The iPhone can be 'seen' by the M2, prompts for the password and adds it to list of preferred networks. Have tried turning offloading on/off, soft & hard rebooting but nothing helps.
Has anyone found the 'silver bullet' to fix this anomoly?
thanx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M2 offloading issue
Please check whether the subnet of the WiFi that you tried to offload the WiFi to is 192.168.1.x. If so, please change either the subnet of the WiFi router / hotspot or M2 to something other hand 192.168.1.x (e.g. change one of them to 192.168.2.x) and see if it works.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Blanca
Understand what you recommend but I run my own local IP addresses on the router not in the 192.168......... range
I'll continue to hunt for a solution
cheers
