Discussion stats
  • 6 replies
  • 1897 views
  • 6 kudos
  • 4 in conversation
Announcements
Reply
Highlighted
Initiate
Nighthawk M2 - selection of LTE Frequency/Band
Hello
I would customize my Frequency/band as the picture, but it s for MR1100
I don't have the good port 192.168.1.1 port 5510 or a another port
Thank you
Vincent
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 7
Highlighted
Luminary
Re: Nighthawk M2 - selection of LTE Frequency/Band
From the photo you attached, seems you have sufficient information at the web site you reached, just follow the procedure provided in that site and you should be able to do what you are asking for here, just AT commands is different from M1, you need to insert one SPACE after AT, i.e. AT!BAND=? changed to AT[SPACE]!BAND=?, all the other commands are the same but need to append one "0" at the end. For example, AT[SPACE]!BAND=03,"LTE B3",0,4,0. M2 does not have space to accommodate that many entries as M1, you can only add up to 5 in total, including original 3 entries.
Message 2 of 7
Highlighted
Initiate
Hello
With Telnet
The command Open 192.168.1.1 port 5510 can t run
Message 3 of 7
Highlighted
Luminary
make sure you have APN set for the SIM card and its IP address is set on 192.168.1.1, connecting to M2's type-C port, not Ethernet or WiFi. These are required for you to configure band selections. Booted without APN set, or without SIM card, M2 would not be ready to connect right after booted, need to wait for few more seconds. If all these still can't make you connected with M2, replace the cable and try again.
Message 4 of 7
Highlighted
Apprentice
On the M1 you can show all Bands with
AT!BAND=?
That means the command should be
AT !BAND=?
Can anyone extract the useable bands from the M2 with this command?
Message 5 of 7
Highlighted
Luminary
Make sure you are on latest FW version, and you can retrieve supported bands with the command AT !BAND=?, tried with 1EEEUS/100EUS and 1TLAUS model.
Message 6 of 7
Highlighted
Initiate
at !band=?
Index, Name, GW Band Mask L Band Mask L ext Band Mask
00, Auto, 0002000004C00000 000001A0080800C5 0000000000 000000
01, WCDMA All, 0002000004C00000 0000000000000000 0000000000 000000
02, LTE All, 0000000000000000 000001A0080800C5 0000000000 000000
0000000000400000 - B1 (2100)
0000000000800000 - B2 (1900)
0000000004000000 - B5 (850)
0002000000000000 - B8 (900)
0000000000000001 - B1
0000000000000004 - B3
0000000000000040 - B7
0000000000000080 - B8
0000000000080000 - B20
0000000008000000 - B28
0000002000000000 - B38
0000008000000000 - B40
0000010000000000 - B41
Message 7 of 7
