- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk M2
I am getting very irregular speeds on my Nighthawk, I have two MR2100 and have tested them side by side with vastly different speeds. I live in a semi rural area and have installed a omni directional mast with a Cell Fi booster. My mobile service is fanatastic. Actual if i speed test my iphone and the Nighthawk the Iphone is constantly faster. Is this the case that Nighthawk can not work with the CellFi boosters?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M2
Hi @MSheer_10 ,
Are you able to provide some details around your speed issue? Can you help to answer the below questions?
1. Firmware version
2. Is it a privately installed Cell Fi booster or carrier approved?
3. What app or program are you using to measure the speeds? (i.e. speedtest.net app). Are you using the same speedtest.net server for the tests?
4. Is the iPhone speedtest done natively or are you using the hotspot feature to connect a laptop or PC?
5. Are the tests conducted over WiFi 2.4Ghz, 5Ghz, Ethernet or USB? Have you tried comparing?
6. Can you please provide details of the speeds obtained via iPhone compared to M2?
Please note that if you are running the speedtest natively on the iPhone(hotspot feature OFF) then you should see some variances in speeds as the M2 has an additional interface inbetween(WiFi, Ethernet or USB).
Arodi
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M2
Current Firmware version is NTGX24_10.13.05.00
Telstra approved Cell Fi booster
speedtest.net
Have tested both natively and Hotspot on Iphone
Have done 2.4 and 5.0 only slightly better on 5.0
No difference using USB connection
Test this morning Nighthawk 5.55 upload 0.20 upload
Same computer connected through Iphone to nighthawk slighlty quicker
Same computer hotspoted to Iphone 20 download 15 upload.
Iphone direct to booster 19.5 and 15.3
Thats why I am wondering if something is required for the nighthawks to connect with the booster or they just cant communicate.
My mobile service is excellent and according to the wave app for the booster I have 4 bars am boosting x8 and am on a 4G LTE connection.
Another point as mentioned in previous post I have two M2's and both are the same but one keeps flicking to 3G
Need help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M2
Hi @MSheer_10 ,
Thanks for the additional information. It is very helpful. You mention that one of your devices keeps switching back to 3G which tells me that they may not be connecting to your Cell Fi booster. If the devices are constantly switching between 3G/4G then this would lead to degradation in speeds. Can you please try the following and let me know if your speeds improve?
Settings>Advanced Settings>Cellular>Band Region>LTE Only>Apply
Re-run a couple of speed tests after forcing to 4G only. You can also try forcing to 3G and compare the result. When you are using the speedtest.net app, please ensure that all tests are conducted using the same speedtest.net server for a proper comparison. The app automatically chooses a server which may give you mixed results. Ensuring the speedtest server is always the same will give you a more accurate comparison. Just something to check.
Arodi
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M2
Have done everything as per your last message with no improvement what so ever.
Have once again hot spotted to the Iphone with a downlaod speed of 30+ and upload of 17+
Nighthawk ran at 6.58 download and 0.34 upload.
