× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk M5 MR5200 Ports
Mindz
Follower
Hi
For our phone app in the company I need to configure certain things (Firewall-Einstellungen (mitel.com)
Hosts
  • *.mitel.io
  • *.amazonaws.com
  • *.bugsnag.com
  • *.gstatic.com
  • cdnjs.cloudflare.com
  • *.chime.aws
  • firebaseinstallations.googleapis.com
  • fcmregistrations.googleapis.com
  • api.ipify.org
  • maps.googleapis.com
  • login.microsoftonline.com
  • 99.77.128.0/18
  • 7443 – TLS
  • 16384 – 32768 UDP (RTP/SRTP)
  • ICMP
  • 443 – TCP
  • 3478 – UDP
Unfortunately, even though I have put port forwarding in place for my device's IP and the ports
  • 16384 UDP
  • 32768 UDP
  • 443 – TCP
  • 3478 – UDP
it still won't work. I cannot select the port range 16384-32768, but would have to add them all manually. Also I don't see the option for port 7443 – TLS and ICMP. And where can I add the hosts as required by the link above?
Thank you
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 587 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
