- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk MR1100 At&T Unlock help without new SIM
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nighthawk Mobile Router MR1100 from AT&T. I no longer use and have discontinued my service with AT&T. I need to unlock to Sell but can't figure out how to do so. I was able to get the unlock code from AT&T with no problem through their Automated system (online). The intructions tell how to do it, but a SIM card from different carrier has to be used. I don't have one, just want to unlock it before selling. Can anyone help with suggestions?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @TxToolman ,
The unlock process requires another ISP SIM to be inserted where the device will then prompt you for the unlock code. The unlock code does not change and is locked to the device S/N. There are 2 options:
1. Use a SIM from another ISP and perform the unlock
2. Sell the device with unlock code printed somewhere
Please note that some SKU's will require the unlock code again if the device is factory reset . I am not sure if the AT&T SKU will require unlock code again after a factory reset but to be safe I would go with option 2.
Arodi
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @TxToolman ,
Arodi
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk MR1100 At&T Unlock help without new SIM
Thanks for your help. I'll just send w/ code.
