× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Nighthawk m1 mr100 - external antenna setup
Submariner3
Follower
Can anyone please tell me how to setup the Nighthawk MR1100 to make the most of an External Antenna.
I have attached a two cable External Antenna to the Nighthawk M1 MR1100 and it makes absolutly no difference to the signal strength.
I downloaded the Nighthawk MR1100 manual from Netgear and on page 11 near the top, it states 'For More Information about connecting an external antenna, see External Antenna on page ?'
So not too helpful. 🙂
Thank you
Message 1 of 2
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Nighthawk m1 mr100 - external antenna setup
Hi @Submariner3
Welcome to NETGEAR Community!
Kindly check the supported bands for use with the two TS-9 external antenna connectors. Please see reference:
What cellular bands are supported by the external connectors on MR1100 Nighthawk M1 Mobile Router?
Blanca
Community Team
Message 2 of 2
All Replies
Blanca_O
NETGEAR Moderator
Hi @Submariner3
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 4307 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
