× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
No Internet connection
Tricia5
Follower
My modem was working fine and then I tried to connect a TP-Link range extender.  It said to reset the WPS button which I did - now I have no internet.  All the other lights are solid green but nothing showing for the internet.  Is there a way I can re-connect please.  I'm going crazy trying to figure it out.  Thanks for any help.
Message 1 of 3
Blanca_O
NETGEAR Moderator
Re: No Internet connection
Hi @Tricia5
Welcome to NETGEAR Community!
Please provide the model number of your NETGEAR router.
Kindly turn off and on the router and check the Internet LED status.
Blanca
Community Team
Message 2 of 3
Guru
You need a router to connect a range extender to. There needs to be something managing dhcp and that'd be a routers function. A range extender doesn't have that capability.
Does your modem (model?) have an integrated router or is it modem only?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 768 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
