- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 firmware question
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been automatically updating my r7000 firmware and I noticed that there is a new version out... the version that i'm on is V1.0.6.28_1.1.83. The latest version is 1.0.5.70. Can someone explain the difference in version numbers and what version is the latest and greatest? Also are all fixes cumulative?
Thanks in advance!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Normally, version numbers increase with each successive release and the fixes are cumulative but Netgear pulled all of the 1.0.6.X releases due to bugs. 1.0.5.70 is currently the newest. If you aren't experiencing any issues, then you can consider staying on 1.0.6.28. If you install 1.0.5.70, then you will lose Arlo camera support. If you don't have Arlo cameras, then this won't matter, of course.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 firmware question
Does 1.0.6.28 include fixes from 1.0.5? if so where can i find the documentation for this? I dont have arlo and i think its probably a better idea to get back to the 1.0.5.x release. Is the upgrade simply chosing the firmware load and then upgrade via the gui or are there other things I need to do like factory default the router first?
- Mark as New
- Bookmark
- Subscribe
- Permalink
1.0.5.70 is newer than 1.0.6.28, so probably not.
Upgrade via ADVANCED > Administration > Router Update in the GUI. You should perform a factory reset after you update the firmware. This will wipe out any incompatible settings from the prior version. When downgrading from 1.0.6.28, a factory reset is especially important in order to get rid of the Arlo settings. Don't restore configuration from a backup file. Re-enter settings by hand.
