- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7100LG LTE router - Attaching cables for outdoor antenna
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I'm very interested in in the R7100 LTE router to inprove my home network. Are any of the 3 antenna 3g/LTE specific? I am wondering if it is possible to remove 2 of the attached antenna on the router and attach a cable for an outdoor antenna? I can't see this information in any of the documents.
4g signal is weak in my home and there is an need for an outdoor antenna for my current netgear aircard 762s.
Correct me if I'm wrong but the R7100LG appears to essentially be the R7000 model with the added benefit of an LTE modem. This would be a massive improvement on my 762s.
Thanks for your help. I'd appreciate any advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7100LG LTE router - Attaching cables for outdoor antenna
Hello WDLandry
Netgear does not support using 3rd party antennas. And you are correct this is a R7000 with a slot to add your micro sim card for LTE internet.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello DarrenM,
Thanks for your reply. I can understand that Netgear doesn't support 3rd party antenna.
To rephrase my question, are 2 of the 3 antennas on the R7100LG dedicated LTE/4g antennas?
Will
- Mark as New
- Bookmark
- Subscribe
- Permalink
