× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Rebooting of Nighthawk MR5100, wifi signal strength loss, alternating between 4G and 5G
LauraArm54
Tutor
I have a few issues with my Nighthawk MR5100.
Where I placed my wifi in my room, after I bought it, a month ago, it showed 5 bars with excellent signal strength at 5G and fast download speeds. It never went to 4G in that location.
A week ago, a month later,  all of a sudden the mobile router's signal strength in that same location went to 4G, with slower download speed and the signal strength varies between poor to fair.
I found a location in my room where the router is at 5G but the signal strength varies from fair to good, but not excellent, not like how it used to be for one month. It can also alternate between 5G to 4G in that location.
A few times the router has rebooted itself.
The temperature in my room has not been too hot and the router doesn't feel too hot.
I use the 5GHz setting.
I have rebooted the router daily and even reset the router to factory settings quite a few times.
Any ideas?
Message 1 of 6
Accepted Solutions
LauraArm54
Tutor
Re: Rebooting of Nighthawk MR5100, wifi signal strength loss, alternating between 4G and 5G
Hi Bianca
Thanks for your reply
The SKU is SKU:MR5100-1TLAUS
My Internet provider is Telstra in Australia.
The firmware is NTGX55_10.29.07.00
I reset it to factory settings once a week and reboot it daily, and no change.
My internet provider said that the tower close to me could have shut off 5G and is doing maintenance...but that was a month ago?
I only get fair to good signal strength, 5G in the one spot...the other areas apoor to fair with 4G
It has rebooted on its own a few times. My room is not hot
Cheers!
Message 3 of 6
All Replies
Blanca_O
NETGEAR Moderator
Hi @LauraArm54
Welcome to NETGEAR Community!
May we please know the device SKU (MR5100-xxxx) and firmware version?
Who is your Internet provider?
Have you tried factory resetting the device?
Blanca
Community Team
Message 2 of 6
LauraArm54
Tutor
Hi Bianca
Cheers!
Message 3 of 6
ArodiD
NETGEAR Expert
Hi @LauraArm54
Can you please send me your IMEI?  It should be on the device label when you remove the battery.
Arodi
Message 4 of 6
LauraArm54
Tutor
Hello!
My the IMEI is 358739540039170
Cheers
@ArodiD wrote:
Hi @LauraArm54
Arodi
Message 5 of 6
LauraArm54
Tutor
Thank you to the netgear on line help support, and to Arodi!!!!!
Problem solved! I was provided an  update and now I get excellent signals in all places in different places in my room.
Previously, my device kept stating that my firmware was up to date everyday when I checked for updates everyday!
Thanks again!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2996 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
