× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Speed on LB1120 Modem
kathon526
Follower
Have LB1120 with Verizon Sim Card.  Getting constant 4-5 green bar constant with external antenna.  Also have GL-iNet Travel Router, Model GL-ar750s-EXT.  The router shows both connections which I can connect too.
The issue is the speed.  I have 0.5-0.8 Mbs download and about 0.6 upload when any router is connected to this modem.
I have two other routers which I have gotten great speeds (30-50 MPS) and replaced on this same LB1120 modem when all three went down to the same slow speed of about 0.5 MPS.  So that tells me it is not the router - I would assume.
I'm not a Tech guy so please explain in detail if you know of a fix or where I might be able to go to get to decent speeds.
Thanks for your support,
Model: LB1120|4G LTE Modem
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 609 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
