- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Streaming issues with Nighthawk M1
- Mark as New
- Bookmark
- Subscribe
- Permalink
I mainly use this hotspot in the car for streaming i-radio. Unfortunately the link to the mobile network gets lost quite often for a short time and therefore the sound interrupts, not quite enjoyable to listen to music this way.
The sim card or the provider itself shouldn't be a problem since I checked it with a mobile phone using the tethering function and it all runs well without any interrupts.
Does anyone have a hint why that is or could be?
Thanks in advance for any support!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyway, testing it further the past days, it somehow seems to be solved. Now it just works fine. I have no clue why that is. A possibility could be that the SIM card somehow must have been "activated" through a mobile phone...? Since I had it in the phone and then switched back to the nighthawk it now runs just fine. I hope it stays this way 🙂
Thanks for any help.
Bye.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Streaming issues with Nighthawk M1
Please advise the device SKU and which carrier you are using.
When you run a speed test, what is the spead you can get?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi John
Thanks for getting in touch.
SKU is MR1100-100EUS.
Carrier is sunrise.
Download speed: ca. 20 MBit/s
Upload speed: ca. 18 MBit/s
RTT: ca. 40 ms
speedtest server is hsi.hsr.ch
These values are in line with the mobile phone that I used as hotspot "reference" (where the music runs smooth).
Thanks, Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bye.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
What did you do exactly to fix this issue? I am experiencing the same. "Activated" the SIM card on an iPhone 7 and hat speed test results of Down: 20 Mbps and Up: 10 Mbps. Inserted the SIM into the Nighthawk M1 and the speed test (iPhone connected to M1 WiFi) ist download of 0.3 Mbps, not even Whatsapp runs. I have tried turning on and off the M1 but nothing.
I would appreciate the help.
Erick
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please advise your device SKU name and your carrier.
At the same time, please make sure you set up the APN correctly on the device.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Erick
Eventually, I only had the SIM card in the mobile phone (android) and afterwards placed it back into the nighthawk again. And it runs well, ever since. I didn't adjust any settings, except, I fixed the WiFi hotspot to only use the 2.4 GHz band - the car only can use this band and since I am using the nighthawk in the car I figured I just fix it to that.
Well, that's it. Hopefully you find a way to run it fine as well!
Cheers, Mike
