× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
USB WiFi adapter and M1 MR1100
Ballard81
Follower
Will M1 MR1100 benefit from a USB WiFi adapter? Would it even work? From asking this question you can probably tell im clueless when it comes to this stuff.
Message 1 of 2
Accepted Solutions
Re: USB WiFi adapter and M1 MR1100
It might help if you said what you want to do.
The MR1100 is a mobile modem/hotspot that connects you to the Internet.
A USB WiFi adapter plugs into a PC and lets it connect to the wifi from your router.
They are completely different devices.  The USB adapter plugs into your PC and lets it connect to the wifi from the mobile modem/hotspot.
Message 2 of 2
All Replies
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1308 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
