× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Unlocked MR1100-1EEEUS
tobys
Once carrier unlocked (by using EE codes provided at end of contract period), what is the difference between their version and others?
from a previous discussion - "The MR1100-1EEEUS is a Europeran version, like the -100EUS, however it's provider locked to EE UK network."
I'm haivng diffiuctly finding firmware that will install as I'm getting "not supported on this device" errors.
Thanks in advance,
Toby.
Model: MR1100|Nighthawk M1 Mobile Router
Message 1 of 2
Ksa3344
Apprentice
Re: Unlocked MR1100-1EEEUS
The difference i saw is bands CA
For example in UK version the band 40 doesn't aggregate with itself but in the EUS it does .
Also UK has B3+B28 and the EUS has B3+B28+B1
I dont know if there is another difference in the other bands combo's.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1079 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
