× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Verizon Novatel USB760
shiphranita
I have a Novatel USB760 stick from Verizon that I am trying to use to connect with my new Netgear Nighthawk AC3200. The USB stick won't connect at all. The connection is usually automatic on my Cradlepoint MBR95, but I can't get it to connect to the Nighthawk in either the 2.0 or 3.0 USB slots. Can anyone help? Or is it just not compatible? 😞
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
JasonN
NETGEAR Employee Retired
Re: Verizon Novatel USB760
Hi shiphranita,
I could not find anything on the compatibility between the Verizon Novatel USB760 & the NETGEAR AC3200.
Please contact support and they will be able to help you with the issue.
http://www.netgear.com/support/contact.aspx
Please let me know. :]
- Jason N
Message 2 of 5
JasonN
Hi shiphranita,
I wanted to check in with you and see if your have got this issue resolved by support.
- Jason N
Message 3 of 5
shiphranita
Well the resolution is that it won’t work.
Message 4 of 5
JasonN
Hi shiphranita,
Thank you for confirming because that was the only results I have seen when researching on the compatibility.
- Jason N
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1191 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
