Exepertise's avatar
Exepertise
Follower
Oct 03, 2020
admin login
Hello,
i cannot my the PIN of my Netgear (model Aircard 797) input. in thr Manual was told using Amin login but I have not it found. please help me.
1 Reply
  • schumaku's avatar
    schumaku
    Head to https://netgear.com/support and enter AC797 - there you find four different model variants. COmpare with the label attached on your device (probably under the cover or battery). Select the appropriate version and review the installation guide or similar. The default administration username and password differs according to the model and carrier.
