× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
antenna why two
rvtips
antenna why two
Why do you need two antennas ?
I have a Wilson trucker antenna can I use it on one of the conntector on the nighthawk?
Phil
Message 1 of 12
Guru
Re: antenna why two
Phil
For what router?
tough to say with minimal info.
But I will say, a CB antenna uses a different wavelength than 2.4ghz, 5ghz, or cellular signal.
Message 2 of 12
rvtips
Re: antenna why two
The Wilson trucker anntena is for a cell phone.
Message 3 of 12
Guru
Re: antenna why two
and what are you trying to attach it to?
And what model antenna is it?
Message 4 of 12
rvtips
Re: antenna why two
I have a Wilson trucker cell phone anteanna that I don't use any more,It only has one connector will that work on my highthawk wifi unit?
Message 5 of 12
Guru
Re: antenna why two
And what end type is on the wilson trucker antenna?
And what nighthawk do you have?
Message 6 of 12
rvtips
Re: antenna why two
I have the night hawk mr1100,the antenna has the same connection as the night hawk,it will srew right on.
I just want to know if I can use just one of the antenna ports on the night hawk.
Message 7 of 12
Guru
Re: antenna why two
you can always try it if the connector is the same. Not out anything to try.
Message 8 of 12
antinode
Guru
Re: antenna why two
> I have the night hawk mr1100, [...]
   Whew.
   I know nothing, but my first attempt to get some useful info from an
MR1100 User Manual (Visit http://netgear.com/support , put in your model
number, and look for Documentation. Get the User Manual.) got me only:
      o TS9 antenna connectors. Two SMK-TS9 connectors for an optional
        MIMO antenna. For more information about connecting an external
      antenna, see External Antennas on page ?.
   Of course, there is no "page ?".  And the equally useful:
      For more information, visit netgear.com/XXXXaccessories.
   My guess is that someone left this noise in the Manual to identify
places where someone was supposed to fill in actual information later.
Which apparently didn't happen.
   There are many variants of the MR1100, so someone who cared more than
I might check the documentation for them.
> night hawk.
   I wouldn't expect any damage, so I'd run the experiment.  (But what
do I know?)
   A Web search for terms like, say:
      Netgear MR1100 antenna
might reveal some interesting material.
Message 9 of 12
schumaku
Guru
Re: antenna why two
Netgear's always brilliant QA and the Harward Business School fire and forget behaviour 8-/  The MR2100 (M2) manual is a little bit more informative in this aspect.
"External Antennas
Using an external antenna might be recommended in areas of lower coverage to improve
your device performance. MIMO Dual RF antennas are available from your retailer. Insert
the connector carefully to avoid damage to your device."
These units (like many earlier AirCard) make use of two radios doing Dual MIMO for the 4x4 system - that's why there are two antennas, and that's why Netgear is offering dual MIMO antennas - at least in some markets. The US site Nighthawk M1 4G LTE Mobile Router - MR1100 | NETGEAR does not list any antenna offer.
The KB MIMO Antenna (6000450) | Product | Support | NETGEAR does point to a data sheet for an indoor antenna MIMO_antenna_DS_07Aug14.indd (netgear.com) from 2014  stating "For complete list of compatible devices please go to:
www.netgear.com/ServiceProviders/AirCardAccessories ... as @antinode would say again equally useful 404. I can't understand what they are making all days long 8-(
@rvtips you can't hurt anything by conncting just one antenna - permitting it's the correct matching connector.  If it does help overall with the reception in your use case ... hard to say.
Message 10 of 12
sinawf
Re: antenna why two
As others have noted, the Nighthawk MR1100 uses MIMO antennas to improve performance. These antennas are cross-poliarized to improve performance. You can see a full guide on how to boost signal for the MR1100 here: https://www.waveform.com/a/b/guides/hotspots/netgear-nighthawk-m1
Model: MR1100|Nighthawk M1 Mobile Router
Message 11 of 12
Transfluxor
Apprentice
Re: antenna why two
The main problem with external antennas for M1 and M2 routers is that the connectors serve only the low-frequency range.
I saw information on the Internet that 1800 MHz and above is only for built-in antennas. Therefore, the fastest Internet just cannot be amplified with an external antenna through the connectors.
It remains to try the LTE amplifier, which takes a signal from an external antenna and transmits it to the router via radio waves. You can also try to connect an external antenna with a cable to the router, but do not connect it, but simply place the central conductor of the cable next to the router.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2714 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
