- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
nighthawk M1 battery indicator
- Mark as New
- Bookmark
- Subscribe
- Permalink
simple question - I have studied the booklet, searched the website and googled 'til my finger bled.. but I can't find the answer.
My Nighthawk thingy has a circular battery light - at least that's what I think it is.
The left hand side semi-circle is half yellow and half purple... the right hand side is all purple.
The base of the left hand side is a small empty battery icon... the bottom of the right hand side is a pair of opposing arrows....
should be pretty self explanatory, I suppose but I'm goshdarned if I can figger it out..
Anyone help??
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: nighthawk M1 battery indicator
Photo please?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Set a limit of your data like 10GB or whatever and you will see how much you have used on the right, yellow means how much charge you have left...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oxygene is correct. The left hand side is the battery level of charge. In the picture you're at approximately 55-60% charged. Top is full, bottom is empty.
Same thing on the right, but for data.
