× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
trying to reset admin password on mr 1100
Mathias87
Follower
So ive tried using "admin" and "attadmin" and "password" but none are correct. i must have changed the password and now dont know it. ive tried to do a factory reset but i have to be able to login to do that.....any help would be much appriecated.
Message 1 of 2
antinode
Guru
Re: trying to reset admin password on mr 1100
> [...] mr 1100
   There's a more appropriate forum for such devices, where you might
find/get better information sooner:
      https://community.netgear.com/t5/x/bd-p/aircard
> [...] ive tried to do a factory reset but i have to be able to login
> to do that. [...]
   Not according to the MR1100 User Manual.  Visit
http://netgear.com/support , put in your (actual) model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Factory Reset
Using the Reset Button" (or "reset").
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 666 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
