Orbi WiFi 7 RBE973
Reply
Activating Armor did stop my PC's ethernet to work
JPLang78
I have a RBR50  Orbi... not even in the model number search btw.
I activated this Armor thing.. on the Orbi App that comes with the IOS app.
on that moment, my PC's ethernet connection that was a lan cable to the router stoped.
no way to get it back. I even deactivated the armor and it did not come back. at the moment I pressed this my PC lost the lan connection, not  even a blinking light anymore at the ethernet.
anyone a idea what happend here? it was really the exact moment as I pressed enable... swap Ethernet gone... wont come back at all, says no cable connected.
I deactivate the Armor in the App. no relieve.
Message 1 of 3
DexterJB
NETGEAR Moderator
Re: Activating Armor did stop my PC's ethernet to work
Hi @JPLang78,
Welcome to the community!
1. Have you tried switching over to another port on the RBR50?
2. What is the status when checking on your adapter setting on the PC?
3. Have you tried connecting the PC straight to modem for isolation?
Dexter
Message 2 of 3
DexterJB
NETGEAR Moderator
Were you able to get this sorted out?
Dexter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1932 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
