- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Any reason to keep Bit Defender Box2 with Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been using the the Bit Defender Box 2 with my Orbi network for quite some time. I have the Orbi RBR50.
My Bit Defender Box 2 subscription recently came up for renewal. With the Orbi's Armor security is there any reason to keep the Bit Defender Box in my network, or is it simply redundant?
I found some discussion of this on other discussion boards, but the info was either dated or seemed inconclusive.
Thanks in adavance for any thoughts and help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Any reason to keep Bit Defender Box2 with Orbi?
They both have a cost for subscription. By "other discussion" did you mean the Netgear Armor forum?
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your reply. I now can not find the discussion specifically on the Box 2. The solution in that discussion was more a decided course of action (to keep using the Bit Defender Box) rather than a determination of whether there was any real advantage to doing so.
If the Box 2 is redundant I would like to remove it from my network and pay for the Armor subscription. If, as a dedicated device, it is doing someting more than Armor acomplishes I would probably keep using it.
Thanks.
