CRLchris's avatar
Nov 30, 2024
Armor - MacBook Air - Install - Priacy and Security - Missing Setting
I am working to install NETGEAR Armor on my MacBook Air. The installation package went fine and the program launches, but I am not able to complete setup.
The program wants me to "Allow All Security Modules To Run:
It tells me to go to:
1: Systems Settings > Privacy and Security
2: Scroll all the way to the bottom and choose NETGEAR Agent
3: Select Allow for NETGEAR System software
I have gotten to that section of System Settings, but the choice of NETGEAR Agent is not available.
Not sure what to do. Any ideas?
1 Reply
  • I think they're using an older installer - this has changed in recent Mac OS versions.
    Try going to System Settings>General>Login Items & Extensions.  Enable it there.
