Orbi WiFi 7 RBE973
Reply
Armor Subscription for 7000P.
Frank038
Initiate
Does the armor subscription replace my Norton anti-virus or just an additional layer of protection? Thank you in advance 🙂
Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Message 1 of 3
schumaku
Guru
Re: Armor Subscription for 7000P.
Yes, the Netgear Armor subscription does allow to install the current BitDefender (as of writing BitDefender Total Security 2019) on all your Android, iOS, macOS, and Windows devices (under a fair use policy).
FMI: Netgear Armor - BITDEFENDER TOTAL SECURITY 2019
Message 2 of 3
Neil53
Star
I did a update and then had to do a reset now my netgear armor does not work was given the number to call the armor and it a big joke they told me they will call me back when they are free tha5was 2 dates ago still have 195days of coverage will never buy a netgear product again they no help with the problem any body else have same problem
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 3 of 3
Discussion stats
  • 2 replies
  • 2423 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
