Orbi WiFi 7 RBE973
Reply
Armor with CAX80 and Orbi 960
svarvel
Hello,
I have a CAX80 with Armor subscription in router mode and WiFi turned off. I then have Orbi 960 connected to CAX80 in router mode. I just want to confirm that the Armor subscription on the CAX80 is sufficient and is not needed also on the Orbi.
Message 1 of 4
Accepted Solutions
Guru
Re: Armor with CAX80 and Orbi 960
Kind of based on needs or usage. You can use the Orbi in router mode if you want too. Will be in a double NAT condition however you can use the CAX80's DMZ for the RBR in router mode to avoid this condition.
Kind of up to you though.
Message 4 of 4
All Replies
Guru
Yes. I would recommend running the 9 series Orbi in AP mode if you have the CAX80 in router mode.
Message 2 of 4
svarvel
Thank you for the quick response. If I am only using the Orbi for WiFi is there any security benefit to leaving it in router mode?
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1903 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
