Orbi WiFi 7 RBE973
Reply
Armor won’t install on router
Mrosent
Follower
I purchased armor and activated in the armor web portal. I can successfully log into the armor portal and install protection on my devices When I attempt to activate armor in the nighthawk app it only offers the free trial. I’ve attempted a factory restore with no success. Please help.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 5
Christian_R
NETGEAR Employee Retired
Re: Armor won’t install on router
Hello Mrosent,
Welcome to the community! May you send me a private message with your email address and serial number for me to check further.
Thanks,
Christian
Message 2 of 5
Pistole
Guide
Hi Christian,
I have exacly the same problem.
About 51 hours ago I bougt a subscription. I can install it on my mac without a problem.
The software on my Rax120 doesnt activate.
I have toggled extern management on the router and serveral reboots without succes.
I will sent you an pm with my emaliadres and serialnumber of my RAX120. Can you please loook in to it?
Grtz Paul
Message 3 of 5
jeffs143
Initiate
I have the same problem. Only a button to try the trial and then an error saying it couldn't be installed.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 4 of 5
Emmarose12
had the same issue back in those days when I got in touch with these type of routers, those were hectic days solved issues like daily jumble answer for gaining my confidence back.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2244 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
