Reply
Armor
AKWillows1
Armor
Hi
So I'm nearing the end of my second week with Orbi and *mostly* everything has been good. I am having some problems with the connection dropping to Apple devices... iPhone, iPad and AppleTV but otherwise ok. I have read a few posts where users are being advised to turn of Armor protection.
I'm trying to figure out what exactly the benefits of Armor are? If  don't renew/switch it off, I assume the router is still protected by a firewall as with any other router? What do I lose by switching it off?
Message 1 of 6
Accepted Solutions
Guru
Re: Armor
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 6
All Replies
Guru
Re: Armor
Good Luck.
Message 2 of 6
AKWillows1
Re: Armor
oops! Sorry! :-)
Message 3 of 6
Guru
Re: Armor
Smiley Wink
Message 4 of 6
ekhalil
Master
Re: Armor
Yes, Orbi has a built-in firewall that will protect your network and will not allow access to your router's port except for those that you allow.
Armor / Bitdefender provides you additionally with:
  • Individual device protection for unlimited number of devices in your network. You can add software to every device to provide you with additional protection for the respective devices
  • On-the-go antivirus protection with Bitdefender Security
  • Security status overview on the all new Armor Dashboard
You can read more about Bitdefender here:  https://www.netgear.com/landings/armor/
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + RBS750, AP Mode, Wired/Wireless Backhaul / Orbi RBR50 + 6x RBS50, Router Mode, Wired/Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 5 of 6
Orbi-Roc
Luminary
Re: Armor
Hi @AKWillows1 . I don't know what your Netgear router configuration is; but I will share my experience any way.
I too experienced chronic Internet drops. I made too changes that got rid of them completely:
  1. I don't have Bitdefender Total Security installed on any Apple devices, except for one iPod Touch.
  2. Using the router's Web page, I disabled Daisy Chain. Daisy Chain is usually ON by default and it works well, but ONLY WHEN YOU HAVE MORE THAN ONE SATELLITE. If your Netgear network consist of a router and ONLY ONE satellite, Daisy Chain should be disabled.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3894 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
