Dribble79's avatar
Dribble79
Follower
Oct 08, 2021
Armor
How do is disable Armor using my desktop? I'm on trial now and my VPN is being blocked. I don't need to pay twice for the same service, I have tried to disable it but have not found a way and it's very frustrating, I'm ready to give the system back to you.
Thank you
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you able to use a phone and the orbi app to disable it?
