Orbi WiFi 7 RBE973
Reply
Bit defender for Orbi and NAS
EricMatson
Follower
I’m wanted an antivirus at my router level. I have a NAS that I want to be protected as well. If I would get the bitfender armor, does it need to be downloaded on each device I want protected? I’m not sure I can download it on my NAS. Would thermostats and security cameras need protected? Thanks.
Message 1 of 3
Guru
Re: Bit defender for Orbi and NAS
Please post about this in the Armor app forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good luck.
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @EricMatson, welcome to the community and thanks for your question! No, you don't need to have Bitdefender installed for your connected devices since the Armor feature is on the router itself. This allows your connected devices (smart home and non-smart home) to be protected as well. Here are some links you can check.
https://kb.netgear.com/000059435/What-features-does-NETGEAR-Armor-offer
https://kb.netgear.com/000059436/How-is-NETGEAR-Armor-different-from-an-anti-virus-software
https://kb.netgear.com/000059438/What-type-of-vulnerabilities-does-NETGEAR-Armor-protect-me-from
Dexter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2548 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
