MotoCandy's avatar
MotoCandy
Follower
Jan 03, 2020
Can I use Bitdefender VPN with Netgear Armor?
I have bitdefender VPN subscription.  I use it when connecting to open wireless networks away from home.  How do I continue to use the Bitdefender VPN when using the Armor Bitdefender Security away from home wireless?
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi MotoCandy, welcome to the community! You should still be able to use the stand-alone Bitdefender VPN feature. There has been no report of it causing any issue when used alongside Armor.
    Dexter
