Orbi WiFi 7 RBE973
Reply
Can't use Armor in AP Mode
OrbiRocks
Guide
I have a Orbi RBK23 system running in AP mode.  I'm unable to access the Security Tab or enable Armor/Bitdefender on it when it is in the AP mode.  How can I run Armor on an Orbi when in AP mode?
If this is not possible, how can I best secure my network?  The Orbi has to stay in AP mode due to the way it is connected.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Can't use Armor in AP Mode
https://kb.netgear.com/000061880/Does-Armor-work-when-my-Orbi-or-Nighthawk-router-is-in-AP-mode
It doesn't work when in ap mode.
You'd have to secure it the old fashioned way.
1. decent log in and password
2. wireless security.
3. smart internet browsing
4. computer/device security.
Message 2 of 4
OrbiRocks
Guide
Seems a little short sighted to me.  Why can't Netgear allow Armor work in AP mode?
Message 3 of 4
Guru
because it ap mode, the primary router is doing all the routing/dhcp/nat/etc.
ap mode disables  a lot of features and leaves the primary router running them
https://kb.netgear.com/000061277/Disabled-Features-on-the-Orbi-when-set-to-AP-Mode
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2366 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
