Orbi WiFi 7 RBE973
Reply
Cannot active trial Netgear Armor on R7960P
santosh_r
Hi,
I have upgraded my R7960P router firmware to latest 1.4.1.50 and it said to active Armor free trial using Nighthawk App. When i go to the app, i can see the Security tab and on clicking it says Verifying account but errors out with message "Error - unknown error"
I have logged into armor.netgear.com but it wont show any router registerd, So how i do i active this trial version.
I have even removed and reinstalled the app but still not working. Please note before performing my firmware upgrade i did a factory reset and upgraded to newer firmware.
Issues seems to be with the app which is giving error to activate. Please let me know how to resolve it.
Message 1 of 8
Guru
Re: Cannot active trial Netgear Armor on R7960P
try turning on and then off remote managment
Message 2 of 8
santosh_r
That didnt work, same error
Message 3 of 8
Guru
do you have a different device you could try with?
Message 4 of 8
santosh_r
When you say device are you reffering to WiFi router or phone? I will try with another phone and see
Message 5 of 8
Guru
different phone to try with.
Message 6 of 8
santosh_r
That also didn’t work. I am still getting unknown error while account verification.
Message 7 of 8
Christian_R
NETGEAR Employee Retired
Hi santosh_r,
May you send me a private message with your email address and serial number.
Thanks,
Christian
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2411 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
