- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Deactivating Amor trial
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Deactivating Amor trial
I would post in the Armor forum about it:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
A factory reset maybe needed.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi
I have an orbi rbk50 and after activated armor my network is not working fine.
all my google devices are not working, my meros light buld does not connect any more.
anyone experiencing the same ?
is there any fix, i disable armor but it still shows as activated.
any help is appreciated, the house stoped !!!
regards,
bruno
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had similar problems with massive outage across devices since activating Armor yesterday. Even these community forum pages had difficulty loading or were stopped - and that was through my wired pc, not wifi. Prior ro enacting Armor the router had been awesome.
I have since disabled Armor in the app (Settings - security), restarted the router and it appears to be better.
Have lodged ticket to understand what issues are, as there is a real lack of info from searches. For now, until Support clarify what is going on, I cannot see any way this Armor add on is usable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI
I ve done the same and i think now things are getting better.
what i realised is that somehow my modem could not send data (upload = 0)
i tryed to reset it with the orbi attached, no good, only works when i unpluged orbi from the modem.
i dont know if that makes sense, but is a fact, worked.
thanks all
regards
bruno
- Mark as New
- Bookmark
- Subscribe
- Permalink
How, exactly, were you able to disable it? There is nothing in my app that I can find to disable it. It is really a piece of junk and blockign all manner of legitimate website.
Thanks!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used the Nighthawk app on my mobile. From the opening screen selected security (or go via Home icon top left, Settings, Security) and the first option is an on/off button to Enable NETGEAR Armor. I just turned this to off and no more problems until such time it is clarified the issues are resolved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here:
Installed firmware update - enabled security and parental controls.
Found that security blocked things like my kids' school website and many other known-good sites so disabled these in the ORBI app. However, whilst it shows as disabled it is marked with Activated and continues to stuff up our internet access.
I have attempted a factory reset on the ORBI Mesh WiFi and also tried a reboot of the fibre router to which it is connected to, but still getting loads of sites blocked.
I cannot find out how to turn off this trial and now I cannot access many legitimate websites!
I can't even get the Netgear support request form to submit - https://armor.netgear.com/supportform
- Mark as New
- Bookmark
- Subscribe
- Permalink
This may be no use to you now, but here's how I did it... in the Orbi app on my iPhone I selected Settings from the mqin Menu... then I opened the Security section, In here is a slider switch called Enable Netgear Armor... slide it to the Off position. That seems to do it. I had to disable Armor because it was messing up my internet connection and totally screwed with my Apple TVs. Armor seems to be a nice idea but it doesn't seem ready for prime time yet... very disappointing as of now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RESOLVED: Deactivating Armor trial
Hi Geoff,
That's what I was doing but the service remained active despite being disabled.
RESOLVED: I finally resolved it by logging into the router using the address on the base of the router http://orbilogin.com then forcing an IP address reset. This immediately allowed access to websites without the need to repeat the disabling of 'ARMOR' in the settings->security menu
Hope this helps others too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did the same thing i.e. sliding the toggle to off in security in the ORBI app. How do you ensure you aren't billed after the trial period?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RESOLVED: Deactivating Armor trial
Thanks for that Marc... yes, the service remained "actived" for me too by "disabling" Armor in the Otbi app. However, I'm thinking/hoping that "actived" just means that I had started up a countdown on the Armor trial period... who knows. Anyway, "disabling" Armor seemed to cure my problems even though it still shows "activated" on the Security button in the Orbi app's dashboard. Just to follow up for the sake of curiosity, when you say you forced an IP address reset, did that mean that you changed the IP address from a dynamic to a static one? I didn't find a place to specifically "reset" as such... just wondering. Sorry to be vague about all this networking stuff... just trying to muddle through it. Anyway, as of now, all is good here... best wishes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure about how they plan to address that... I'm guessing that when the trial period is over Netgear will require payment to continue with the Armor service. If at that time we don't pay the bill, that will be that. Armor should simply continue to be "disabled" while everything else Orbi does should still continue to function as normal. Best wishes... G
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @marccr0wley You state in your last post that 'forcing an IP address reset' did solved the problem for you. How is this done exactly -- just like an earlier post from another user with the same problem, I'm not clear as to how to proceed with this. Thank you in advance for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think what's been so confusing to people is that there are two places you can go to "security" in the app. Don't go to the icon on the screen with the little security picture. Go to the little lines in the upper left corner and then to settings and then to security. It took me two hours to figure this out!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @ginginbread . Perhaps I am missing something. Whether I click on the Security icon on the main screen or hit security via Settings, I come to the exact same page where I can enable or disable Armor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your solution worked perfectly!
- Mark as New
- Bookmark
- Subscribe
- Permalink
