Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Disable Armor - Causes printer time print
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-09-28
11:37 AM
2020-09-28
11:37 AM
Re: Disable Armor - Causes printer time print
Hi Doug
I'm trying to get rid of Armor without having to do a hard reset of my router. The mobile app is useless since it always times out after 60 seconds when you try to disable armor under settings/security.
How did you remove armor from your Orbi router?
I did telnet to my router and found bitdefender under the following directory: /mnt/bitdefender
Did you change the startup parameters under /mnt/bitdefender/etc/init.d ?
Message 26 of 26
- « Previous
- 1
- 2
- Next »
Announcements
