Orbi WiFi 7 RBE973
Reply
Disable Armor on singular device
ggarris1
How do I disable armor on a singular device and not affecting other devices in network? I want protection on all devices except one that needs freedom to go anywhere without restrictions. Operating with Mac OS14 and using Nighthawk app. My Android TV box needs freedom to all Urls.
Message 1 of 4
Guru
Re: Disable Armor on singular device
Un-install Armor on this one device?
Message 2 of 4
ggarris1
My whole home network for my trip-band router is controlled by Nighthawk and uses Armor. I only see where you select Armor ON for complete network or OFF.
Thanks
Message 3 of 4
Guru
You can only enable or disable Armor from the mobile app that covers the entire network.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1030 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
