- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I see blocked sites/URLs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Netgear Armor installed on my Orbi router. How do I see which URLs it has blocked on each device? If I don't have Bitdefender installed on individual devices, only on the router, how do I manage blocked sites? All the current instructions for unblocking sites only apply to blocking done at the device level, not the router level.
Also, I see on the armor front page that no vulnerability scan has been run yet. But there is no option to run a vulnerability scan. Where is that button?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I see blocked sites/URLs?
Hi @theodicies, welcome to the community! You can view the threats blocked per device on the Armor portal. You go to https://armor.netgear.com and login > Devices > Select the device > Under Threats Blocked. As it stands, there is no option to do a manual scan. Scans are done during the activation and on a weekly basis as described here.
Dexter
