Discussion stats
Announcements
Top Contributors
Reply
Highlighted
NETGEAR Moderator
Re: How to Activate NETGEAR Armor
Hello Falco1082 & xahmol,
May you try enabling/disabling remote management to see if that would help. I've included an article on how to toggle the remote management feature on/off using the Orbi app.
https://kb.netgear.com/000061809/I-get-an-error-when-I-try-to-activate-NETGEAR-Armor-what-do-I-do
Christian
Message 26 of 29
Highlighted
Managed to solve this by updating to the latest firmware.
Did not know there was a new firmware as both the app as the webinterface of the router stated there was none. But via a support ticket now did found new firmware. And now activation worked.
So solved for me.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 27 of 29
Highlighted
I just bought the orbi RBK23 and I can't get netgear Armor to activate. The software is up to date
Message 28 of 29
Highlighted
NETGEAR Moderator
Hello basilscott2121,
May you try reinstalling the Orbi app and attempt to enable Armor again. You may also try enabling and disabling remote management in the Orbi app.
Thanks,
Christian
Message 29 of 29
