Discussion stats
  • 0 replies
  • 134 views
  • 0 kudos
  • 1 in conversation
Announcements
Top Contributors
Reply
Highlighted
How to whitelist traffic from specific applications?
I have recently purchased the RAX120 router and experienced an issue with the Netgear Armor.
I'm constantly using a streaming service from https://tw.iqiyi.com
And Netgear Armor keeps blocking the streaming URL, here's an example:
http://210.61.180.68/cdnetworksoversea.inter.iqiyi.com/videos/v0/20200414/67/87/29dc23e63ee1742e0e31...
This is blocked by Netgear Armor and identified as "Malware".
However, as you can see it is a video stream served from CDN and the IP and URL will be changed if I'm watching different video content.
It appears that allowing trusted IP in Advanced > Security > Block Websites might help a bit, but right now I can only add one trusted IP - not sure if I'm right on this?
Is there a way to whitelist traffic from specific applications?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 1
