Orbi WiFi 7 RBE973
Reply
I cannot remotely access my Apple Home devices and Q-See cameras after installing ARMOR Security
HSGehlar
I have ORBI RBR50 AC3000 Tri-band router, recently updated to firmware V2.5.2.4 and enabled Security. Now I cannot remotely access my Apple Home devices and Q-See cameras after installing Armor Security on ORBI. When I'm home they all work fine. I rebooted/reset everthing, that did not help. Any idea? Your help is appriciated.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: I cannot remotely access my Apple Home devices and Q-See cameras after installing ARMOR Security
You can check whats being blocked in the armor dashboard and unblock things.
  1. Launch the Nighthawk app from a mobile device that is connected to your router’s network.
  2. Tap Security.
    The NETGEAR Armor dashboard displays.
  3. Tap the Threats card.
    A list of suspicious blocked URLs displays.
  4. Tap on the URL that you want to unblock.
  5. Tap Add to Unblocked.
    A warning displays.
  6. Tap OK.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1219 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
