Orbi WiFi 7 RBE973
Reply
Moving Armor Subscription
volvocyberguy
HI,
My RBR50 failed last week, just would not initiliase after 2.5 years of loyal service, so I purchased a second hand RBR50, as who wants to replace their entire meshed WiFi before Christmas. The thing is, my Armor recently renewed, and of course it is not recognised on the replacement device, so how can I get it deactivated from the old system (which won't power-up) and enabled on my replacement RBR50?
Cheers,
John
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: Moving Armor Subscription
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
You'll need to go through support to transfer the subscription over.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1864 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
