Bigboi816's avatar
Bigboi816
Follower
May 04, 2025
NETGEAR Armor has detected and blocked a network attack on Synology-DS918+
Hello,
I recently replaced my old Orbi system with the Orbi 750 Series AX5200 Tri-Band Mesh Wi-Fi 6 System and I’m trialing NETGEAR Armor. Since beginning the Armor security trial I started receiving the following message multiple per day everyday. “NETGEAR Armor has detected and blocked a network attack on Synology-DS918+ from 78.153.140.179. An external attempt to access protected files on Synology-DS918+ was blocked to prevent remote code execution. You're protected and don't need to do anything else.”  I’m hoping one of you guys can help me find the solution to this issue.
Thank you,
