- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear ARMOR disabled [R8000 — Nighthawk X6 AC3200]
- Mark as New
- Bookmark
- Subscribe
- Permalink
V1.0.4.84_10.1.84
Hello,
I wanted to check the device security (mobile phone) on Nighthawk App. When I choosed the device from the list and tap Device Security i found the pop-up "Please enable Armour on your router". So, I logged into my R8000 and checked what's happened. The ARMOR Security is disabled (however I do not disable it) and I could't enable it, the option is locked. My ARMOR subscripion is valid to March, 2024.
What's happened. How can I enable ARMOR on my router?
Thanks,
Mikolaj
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear ARMOR disabled [R8000 — Nighthawk X6 AC3200]
Any progress on this?
V1.0.4.84_10.1.84
Hello,
Thanks,
Mikolaj
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What mobile platform are you using? Android or Apple?
What version of the Nighthawk app are you using?
Generally Armor can only be enabled and access thru the NH app. Theres no Armor controls on the routers WEB GUI page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
App version 2.30.1.3220
When I tapp the Armor icon in the NH app there is a pop up "Unknown error".
When I go to Device Manager, find my device, tapp on it and then tap on Device Security there is another pop up "Please enable Armor on your router" - please find the screen shot from the app attached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please submit a bug report thru the NH with all available screen shots so NG knows what to look for.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
