- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Armor blocking a site but doesn't show URL to allow unblocking
- Mark as New
- Bookmark
- Subscribe
- Permalink
I use PumpSpy to monitor my sump pumps and have never had a problem with receiving messages through my wireless network (PumpSpy only communicates to an associated app through the wireless network, no internet usage). Two days ago, I started getting constant messages that Netgear Armor was denying access to a potentially harmful website (which is PumpSpy sending updates to its app about water level, warnings, etc.), but since there is no URL, there is nothing to unblock. Is there any way to get Armor to ignore threats from a particular device? Armor shows the device as "Inventek Systems iot" but I was able to confirm it is my PumpSpy devices being blocked.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, so that seems to have worked. I went to the Netgear Armor page on the web and did as you said. In the notification window, I clicked on the unblock. Then I went to the app and turned off the Armor protection. Reconnected my pumpspy to the network. I decided to put it on my guest network, since it was sending unencrypted data. I'm doubtful if that would cause me issues, but at any rate, I feel safer... Then I turned back on the Armor in the app, and it now seems to be connected without the annoying notifications every 15s. Hopefully, this does the trick and it stays like this. Thank you for all your help on this. It was very frustrating!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Armor blocking a site but doesn't show URL to allow unblocking
The warning message won’t stop and it is annoying the **bleep** out of me.
I have had the PumpSpy for about 9 months and this just started happening overnight.
Can someone please help to fix the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found the solution of netgear armor blocking pumpspy is for the user to go to armor security on the app. Than on the time right under notification you will see it blocking the pump spy url and than you just have to click the notifcation and allow it and it will unblock it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same issue, but there is no URL. When you click the Unblock button, it just shows up in the Unblocked URL as "Privacy". You can't even click on it or do anything with it. Until there is a solution, I have to block the device in the router table. Otherwise, every 10 seconds I get that same annoying notification. I contacted PumpSpy as well and they are aware of the issue. However, they just say to unblock the device in the router table, which just brings back the annoying notification! It's a shame, I really like the device and has saved me a couple of times with my sump pump. Would really like a solution on this one. Notice there is no URL in the notification.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
after that i turn off armor and allowed the pump spy to connect back on and than turn armor back on it stayed connected hope that helps. It worked for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also it may show ones you turn back on again armor might have another notification that it block pump spy just unblock the new url.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, after about 8 hours or so, the issue has returned. I think we are going ot need Netgear support on this one. It seems the A.I. is blocking the communication and there is no URL to allow.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm finding this fix is only lasting for a few hours before I have to repeat the process. Is anyone else having a similar experience?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the solution only seems to work for a few hours for most. I reached out to PumpSpy to see if they have contacted Netgear or have any solution. Hopefully, they come up with a resolution soon. If I hear anything, I'll post it. I suggest that more of us reach out them so that they will understand how many people are affected.
