mrsgarfield's avatar
mrsgarfield
Netgear Armor detected suspicious connection on Zhuhai Raysharp DVR
Hi,
I have Orbi RBR50 with 2 satellites. Recently, I have been receiving 2 to 3 times a day on following notification on my Orbi App as below:
'Netgear Armor detected that a suspicious remote location (ip address) attempted a connection to Zhuhai Raysharp Technology and blocked that connection.'
Every time it is a different IP address. Has been on going for last few weeks.
I uses a VPN and I am not sure if the Zhuhai Raysharp DVR is the NightOwl Security Camera or the Directv DVR.
Can you please help me to fix this problem?
Also, do you think I should upgrade my Orbi and is it safe to install Bitdefender?
Many Thanks
1 Reply
  • Hi,
    Or if someone can recommend who I can contact to fix this problem. I received that suspicious alert 3 to 4 times a day.
    Appreciate all the help. Thanks.
