Orbi WiFi 7 RBE973
Reply
Netgear Armor installation
D-Mac
Just wanted to check and see if the way this is set up falls under one subscription or two?
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: Netgear Armor installation
Hi @D-Mac,
Welcome to the community!
It should be under one subscription.
Dexter
Message 2 of 4
D-Mac
Thx Dexter...
Do you know why some phones show "b" icon and others dont.
Message 3 of 4
DexterJB
NETGEAR Moderator
Yes. Those are the ones where you have the BitDefender local protection app/program installed.
Dexter
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2112 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
