- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Armor on R800
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Last year in November purchased the Netgear Armor with bitdefender subscription for 12 months. There was an auto renewal in place and it successfully renewed in November this year for a further 12 months.
I cannot remember if i renewed/activated my subscritpion this year. Last night did the firmware upgrade to V1.0.4.66_10.1.75 and then when i logged in to my Web GUI - i noticed the Netgear Armor status showing as "Not activated"
Looks like i may have accidentally deleted the activation code sent by email earlier - is there a way i can get another code sent to activate?
Thanks
Kevin
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
With this factory reset and having to redo all the circle entries - the radios appear to be stable.
Is there any method of reading the old config file .cfg?---I wouldn't. the change to armor was a significant change for routers. Many ran better after factory reset and clean install because of how much it changed. I'd stick with just doing a manual setup this time and then make a new backup in case it happens again.
I dont want to load it on the router in case something in the earlier settings may have caused the issues.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Armor on R800
there's a support link on this page to click on and check status/get support
https://www.netgear.com/support/product/netgear-armor.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans - thanks for that - have raised a ticket and shall wait.
I did see the site initially and ignored the option below for without a serial number and completed all the details of my router - to be advised the complimentary support had ended 4 years ago 🙂
Got to learn to remove my blinkers!
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hope it works. The router support might have ended but your support through bitdefender for its services should still be able to be used.
potentially also @Christian_R could help as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Will keep this thread posted - in case I run out of luck.
I have received a response - first level i suppose - the usual links to KB articles.
In the meantime for some strage reason the router decided to factory reset itself - luckily had a backup copy of the Config - so was up and running in 5 minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Armor uses Bitdefender. you can also try going through them.
Support Consumer - Bitdefender Consumer Support Center
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Plemans - this morning the router decided to do another factory reset again - so used the oppurtunity to go through and configure the router (using the nighthawk app rather than the desktop) and the most painful part - configuring the whole of circle (1st gen). This activated Armor and seems to indicate my suspicion all this while - Circle somehow is not very reliably operating on this router.
Just for the record - in case someone else has this issue in the future - i first seemed to have a very unsteady 5_1 GHz radio which i disabled and everything else seemed to work for a while then the same thing occured on the 5_2 GHz radio whihc i disabled again and everything opertaed for a while. Then very erratically the router needed a reset almost everyday - then with some time available over the holidays - i started checking and found the new firmware and did the update and from there on all in this thread earlier!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
