Orbi WiFi 7 RBE973
Reply
Netgear Armor working on RBR40
StevenOrbi
Tutor
I have installed Netgear Armor on RBR40 (model RBK43). I see this is not supported. It seems to work fine. Am I missing something?
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 4
DexterJB
NETGEAR Moderator
Re: Netgear Armor working on RBR40
Hi @StevenOrbi, welcome to the community! The RBR40 is among the supported models as listed on the link below.
https://kb.netgear.com/000060582/How-do-I-activate-NETGEAR-Armor-on-my-Orbi-router
I'll let the team know for them to look into the website. Thanks for noticing!
Dexter
Message 2 of 4
Username4Pro
Hi, just ordered the RBK44 kit. I don't see a reference to the RBR40 being supported in the link you shared. I had only come across another page that just listed the Orbi RBR50 kits.
Just wanted to confirm the RBK44 is capable to support Netgear Armor, as this was one of the primary reasons for purchasing.
Thanks!
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @Username4Pro, welcome to the community! Yes, the RBK44 is among the models that support the Armor feature. On the same link, it is listed on the top right hand side (This Article applies to:) and click "Orbi" for the list of devices/models.
Dexter
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2116 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
