Orbi WiFi 7 RBE973
Reply
Netgear Armor
updatedmike
Netgear Armor
I swear Netgear Armor enabled itself today.  I don't want this and didn't sign up for it.  I've had this router for a couple weeks and it just enables on its own?  I didn't think this could happen but I swear it did.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 6
Christian_R
NETGEAR Employee Retired
Re: Netgear Armor
Hi Mike,
Would you mind sending me with the email address and serial number of your device. I'd like to look into this further.
Christian
Message 2 of 6
Bill_160
Tutor
Re: Netgear Armor
I have the same router and it enabled it today by itself too.
Message 3 of 6
KennyG944
Star
Re: Netgear Armor
Sounds like this would make a good class action.
Message 4 of 6
Christian_R
Re: Netgear Armor
Hello Bill_160,
May you send me a private message with your email address and serial number for us to check further.
Thanks,
Christian
Message 5 of 6
updatedmike
Re: Netgear Armor
No - I'm not comfortable sharing the serial number.  I will tell you that I just recently had a RAX50 which I did activate with Netgear Armor.  Running the secuirty software significantly decreased my speed so I disabled it.  I then returned the router for the RAX120 which I did not enable Netgear Armor on (nor will I).
Thank you,
Mike
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2903 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
