Orbi WiFi 7 RBE973
Reply
Netgear RAX30/R7000 Bitdefender and Netgear Armor
gjblajian
Star
Ok, I have the RAX30 and the R7000 and have purchased Armor for both (though the only subscription that shows up is the R7000 for some reason)
I have installed Bitdefender (supposedly included in the Netgear Armor subscription) on at least 2 devices but when I log in to Bitdefender's website I have no devices
and no subscriptions
I understand that NG Armor and Bitdefender are "kind of" separate products but I would think that their collaboration would allow you to use the Bitdefender resources. Am I doing something wrong or is the collaboration significantly less than fully integrated?
Message 1 of 2
schumaku
Guru
Re: Netgear RAX30/R7000 Bitdefender and Netgear Armor
it's not the very same. Builds, versions and API can differ for example. Either way, it's not freely exchangeable.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 745 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
