Orbi WiFi 7 RBE973
Reply
Orbi RBK850 No Netgear Armor and Disney Circle?
jodax
Apprentice
I cannot seem to see any options to enable Netgear Armor on the new RBK850 (I am currently paying for the subscription through my previous Orbi-RBK50).
Should I cancel my Armor subscription and ask for a refund? or Return this seemingly feature less Orbi Wifi 6 and go use my old RBK50?
I have the latest firmware (v3.1.5.23) as of this writing.
Message 1 of 4
CrimpOn
Guru
Re: Orbi RBK850 No Netgear Armor and Disney Circle?
You may get more informed comments in the Armor community forum
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
Message 2 of 4
jodax
Apprentice
I got a reply on r/Orbi subreddit... apparently its in the product roadmap, so they pretty much released the hardware with limited features on the firmware side. I guess i should have waited before rushing to purchase the RBK850. The main issue now is Netgear didn’t say how ling before the enable Armor. If history on How ling it took Orbi RBK50 to get armor after they released it on the nighthawk routers are to be repeated, it will probably take a while before i can use my subscription again. So ill probably cancel it
Message 3 of 4
Guru
Armor and Circle are not avaiagle at this time. Same happened with Orbi AC models. NG came out with Armor and Circle at much later time frame and presume NG will do the same with Orbi AX.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2740 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
